I have a 1996 Glastron GS 205, with the Alpha One Gen II, 5.7. The 1st problem, is I'm not getting 12 volts, to the coil. I've run a wire, to the coil, from the battery via a switch, up by the console. The 2nd issue is the motor "falls on its face" when the RPM's go over 3000. I have changed the gas filter, and the carburetor, but nothing is working, to correct the problem. I've been told that it might be the Neutral Saftey Switch, but have no idea where to go from here. Any suggestions will be greatly appreciated.
