Accessory switch wires
Ramdave
Hello All, I have a 2006 crestliner fish hawk 1750. There is an accessory switch on the switch panel and wanted to connect my radio to it because of parasitic draw issues, that way I can just turn off the switch and cut power to the radio. For the life of me I cant find the feed wires for the switch, found 2 connectors not used under the dash and neither one of them will power up with the switch turned on. Does anybody know where the accessory feed wires are and color. I pulled the switch panel and every switch is wired with orange wires.
Thanks in advance for any possible help
mr 88
A test light or a multimeter is your friend when owning a boat that has a battery . Trace and check for power at your connections.
Ayuh,.... Welcome Aboard,...... Daisy chain it from a switch that works now,.....
orange is the color for items getting power directly from the alternator or the accessory feed.
Ramdave
So there should be a single orange wire under the dash not connected to anything.....yet?
Ramdave
Now that makes sense, you just run the new wire from the switch to your accessory.
