Bought a 17' bowrider last summer. 1988 Alpha One Gen One with 3.0. Have been going through this winter doing maintenance. One thing was had gear lube in the u joint bellows and found a groove worn in the yoke on the input shaft where the seal rides. Repaired that and did pressure test last night. Held 12 psi for an hour with no change. Turned shaft and shift shaft several times. Let it down to 10 psi and it has stayed steady from 10 PM last night to noon today so I think I'm good to go in this area. I've read to do vacuum test but that Mercury recommends not to do vacuum test so I will probably skip that part. Anyway, I was wondering what people's opinions are about adding the oil reservoir kit to this outdrive. I know the kit isn't available from Merc anymore but NOS are available. Is it worth the money and time? I will just use this boat a few weekends in the summer and for a week on a yearly vacation. Not getting a lot of hours. And part of me says it's been fine for 32 years and I'm looking for a solution to an imaginary problem so don't worry about it. The other part says it wouldn't be that hard to add the kit and pretty much eliminates pressure and vacuum being developed in the outdrive and makes it easy to watch for leaks Thoughts?
