fibersport
- Jul 18, 2010
- 104
Re: adding trailer brakes and trany cooler
The nice thing about surge brakes is that you can tow the trailer with any vehicle and won't need a brake controller. They can feel a bit wierd at first as there is a very slight lag between the vehicle brakes applying and the trailers but you get used to it. Disc brakes will require a connection to your backup lights as there is a bypass solenoid that needs to be in the trailer brake line circuit. Not sure what year you van is but I have an '05 Town & Country, be very careful when connecting the lights. I strongly suggest one of those isolators that draws power from the battery rather than from the wires to the bulbs, it acts as a relay circuit and helps protect the BCM (body control module). The wiring on the newer vans is very light gauge and can cause problems if not protected.
