briangcc
- Jul 10, 2012
- 2,416
What? Sailing vessels have horns? I thought only powered vessels had to have operational horns.
Let me ask you a question....as I assume that you are a power boater...what's in your Coast Guard kit? Whistle? Air horn?
Why do you carry those? It's simple really....what happens when your battery gives up the ghost? How exactly do you plan to use your electric horn with no power?
In that instance, where your battery is now dead, consider yourself a sailboat as you are no longer under power.
Simple enough?
Now...electric boat is considered a power boat and subject to the SAME regulations as a gas guzzling boat.
At idle, my Honda 115 was so quiet that the only way you could tell it was running was listening to the tell tale hit the lake. By your argument, because my boat was so quiet, I would need a different set of rules to announce I'm there? Doesn't the 17'6" boat that the motor is attached to give you that indication already?
You're severely overthinking this.
