Adequate cooling for running engine in boat yard
Mkongsiri
Hi, I'd like to run my newly rebuilt engine before we launch this coming weekend. The previous owner had attached a hose adapter to the water intake line as shown in this photo:
When I run water through it, it just seems to come out the outdrive and I'm not sure if it's being pulled into the engine at all. I'd appreciate any input on whether this is sufficient for running the engine or do I need to get the OMC trunion cap adapter?
Thanks in advance for any assistance!
Redrig
Master Chief Petty Officer
Re: Adequate cooling for running engine in boat yard
yes , that works . I have one in the same location on my 302.
Just make sure that you have enough hose pressue. If worried just feel the manifolds or risers , if they are getting too hot to touch - kill it
but with adequate pressure from the hose you will be fine , just dont go above 1500 or so RPMs
HT32BSX115
Also, make sure that your raw water impeller is either removed, not turning or has water to it or you'll destroy it quickly.
Howard Sterndrive
just turn the hose on full and water will flow back to the impeller and lubricate it- should work fine
all water comes out the drive after it goes through the engine
southkogs
If that's on the same drive set on your other post: check the sterndrives for a hose fitting like in this photo.
That's a fitting that runs water both down the drive to the impeller and up into the engine. It was optional, so some drives don't have 'em.
Mkongsiri
Unfortunately, I don't have that hose fitting on my intermediate.
Mkongsiri
I only have the intermediate attached right now, upper and lower gear cases are not. Will that be a problem?
bruceb58
your water is going to leak out the trunions. Yoiu can run it but you need to put a clamp on the hose going back to the drive so it doesn't all leak out there.
Mkongsiri
Ok, but will the cool water circulate if I close that off? Wouldn't that just make it closed loop? Maybe I'll just put the lower drive units back on then run it....
bruceb58
Yes it will. With the drive on, the water kinda reaches the backside of the impeller and just stops there.
