adjust helm steering? - play on 74 mercruiser
CamaroMan
Hi there. SO had my 74 searay 220 out last weekend for the first time. Apart from the boat "biting" twice quite sharply (ok it was a bit rough) - I also noticed a bit of play on the steering.
After doing some research - I found the mod had been done (2 side holes). I removed the plastic plugs today and everything inside is brand new / shiny, but the bolts were a bit loose. I snugged them up by hand (silly torque wrench I rented was a really low strength one).
Anyway - I noticed about 3/4" max movement on the whale tail end with steering wheel not moving -
Next I steered all the way left and strap tied the stern drive to the U bolt to the side of the boat to keep it in place - I went to the helm and rotated the wheel a bit.. I can see into the back very well and the amount of play in the front was about 2 inches without the cable moving - I could feel the gears in the steering being worn.
Is there a way to adjust this front steering rack or do I need to replace it?
My control looks like this:
http://i.ebayimg.com/images/i/172362904623-0-1/s-l1000.jpg[IMG]
My steering rack looks like this:
Nope,.... No adjustments,.... Replacement usually involves a helm, 'n cable Kit,....
