Adjust or replace key ignition? Key only comes out in ON position.
Hello, i can’t remove the key unless it’s in the on position. I read elsewhere that this should be able to be fixed by adjusting something on the back to get the lock lined up correctly. Looking at my ignition, I don’t see any way I could do that. Do I just need to replace it? Or am I missing something. Thanks
Pictures of ignition
buy a new ignition switch
Ooof, actually I think I had it wrong and maybe some stuff is wired incorrectly. The manual online said it has a 3 position switch but this is definitely a 4 position switch. So the second position is the off position. There’s no difference in what works with it on accessory or off so I just got it mixed up and thought it was only 3 positions…. I might delete this post from embarrassment lol
redneck joe
Too late, after an hour you cannot delete. We will make fun of your for eternity....
We have all done similar, no sweat.
