Re: adjusting timing (Chev 305 IB)
Thanks, Boatist. I marked the position of the distributor after I timed it with the light, so the adjustment I'm fooling around with now is in reference to that mark. When I advance the timing just a bit off my mark, the motor sounds smoother and quieter -- rpms increased by about 300, so I backed off the idle adjustment screw to compensate. I'm looking for it to run just a little bit cooler, as I'm thinking I might have had it just a bit too retarded (My assumption is that running too far retarded will cause it to run hotter.) It's hot out and the water is warm now, but the temp was hitting 180 and that seems a little hot (goes back to about 160 after throttling down to about 1000 - 1200 rpms for a bit). When it warms up at idle from cold, it holds at a little under 150 (holds that temp indefinitely, if I just let it idle in the slip).<br /><br />If I understand you correctly, advancing the timing a bit might increase power (higher rpms?) -- but it could give me some pinging (a sign I advanced the timing too far). Based on your response, though, I might be wrong about the effect on engine temp -- advancing the timing might in fact make it run hotter (?)<br /><br />I'm making these adjustments at idle speed, and I guess you are saying that doing it at WOT would be better. I very rarely have run at WOT, and then for only short periods -- guess maybe the pinging would only be noticed at the top end, though, so I should at least try out the timing setting under load at something close to WOT. (Can I assume that rpms on the top end will likely be higher when timing is advanced? I usually run under 2500, although I think the manual calls for 4500 rpms at WOT -- maybe 5000.)<br /><br />Hey -- Thanks.
