Captain Caveman
- Mar 1, 2005
- 1,030
Long story short - I bought an old 70s pontoon with a 93 Evinrude 2-stroke. Motor runs great but the motor was losing fuel pressure. Squeezing the bulb didn't help much. The hose is new so I switched tanks. I pulled out an old Chrysler Tote Tank that I had sitting in the shed and everything worked great. However, the top of the gas cap fell apart. There should be a plastic shroud (see bottom pic) over the red float indicator that has the air screw valve. The shroud crumbled to my touch and I'm left with this below. The pontoon sits out on the lake all summer and I don't want rain going down that hole in the center of the gas cap.
Temporarily I threw a baggie over the cap. It's not a standard threaded gas cap but has the two arms that twist into place. I searched all over the internet but can't find a vintage replacement. Any thoughts on finding a replacement cap to keep the rain from mixing with my gas?
Here is a picture that I found online of the tank with the gas cap with vent screw and shroud in place.
