rockstar01
- Apr 14, 2012
- 13
HI, I am new to boat restoration, and would like to repair the deck on my '87 four winns horizon 190. There is a soft spot on the deck, on the starboard side towards the rear of the gas tank. When I open the cover it seems that some previous owner may have had another plywood floor installed over the original one? Or is this supposed to look like that?
Also in the photo where I am showing my finger pointing, is this a stringer? is it supposed to be covered in fiberglass?
I am happy to remove the old deck, and fabricate a new one with plywood, would it be prudent to only replace the damage spot or would replacing the whole floor be necessary?
Also how easy is it to repair a stringer, I am guessing you need to cut out the damaged section, replace the wood, and re glass. How to you adhere the new wood to the old (good_ part) of the stringer?
Any advice would be helpful.
Thanks Jon.
Thanks Jon.
