Advice on transom , stringers and floor rebuild
carlos515
I gutted the interior today. My idea is to update the cockpit as well as the interior. I will remove the indoor outdoor carpet as well. I still have to grind the ski locker and fiberglass it. But it has been hot for a few days , did not feel like wearing my tyvek suit . I have 2 layers of 1708 and 2 layers of matting on the floor. I am thinking of sanding the floor and rolling gelcoat with soft sand anti slip mixed in. Then making snap in carpet.
carlos515
I would like to change my dash and the passenger dash also. I was thinking of making a frame out of wood and covering it with mat, woven roving , mat then 2.3 oz fiberglass cloth. Then gel coat to finish.
There will not be any structural support needed.
My goal is to re-locate the gauges and go to rocker switches. I would also like to put a stereo in the Captains cockpit. There is no room as it stands now.
Or would I get away with epoxy and carbon fiber plain cloth or 4.6 oz ud carbon IM7 ?
carlos515
That is 1 layer of the carbon fiber as opposed to all the layers of fiberglass.
carlos515
I figured out that epoxy and carbon fiber is not worth it. I will use 4 oz glass and form a new dash.
On another note....what height are the average bench seats in a bow rider? I have my board on milk crates and it seems a little on the low side. Measures 11 inch to bottom of plywood.
carlos515
This is what I am thinking for a bench. I will shorten the one seat to fit in the opening. Or just fiberglass the corner and put gelcoat and soft sand , use it as a step.
carlos515
Thanks, that is a great idea. I will try and make arm rest with a cup holder.
carlos515
I gutted the dashes. Someone had screwed on the molded fiberglass instument dash. I am in the process of changing the look of the starboard dash, also to add a stereo.
I am also starting to remove the carpet........Face to palm. I will not put carpet in any boat from now on , unless it is the snap in removable kind.
carlos515
Baylinerchuck
Yeah, that stuffs a pain to get up. Nothing really cuts the hardened glue, and clogs the crap out of sanding discs.
carlos515
Well got around to removing the inner bow fiberglass . Did not do this earlier in the build. I was in too much of a rush to get the boat in the water. Now I realize....never rush , just makes extra work for yourself. I need to seal the new floor to the original front bow floor. I can now also attach my seat cusions properly .
carlos515
The interrior is stripped. Would it be a bad idea or not to fiberglass 5.2mm Luaan Mahogony to put on the floor to cover the semi fresh glue? I then can gelcoat and sand treat the floor.
What is the average weight of everyones rear deck / engine sunpad cover? My shocks for the lid are only rated for 100lb each.
Baylinerchuck
So you’re putting down plywood to coverup the glue from the last carpet? How do you plan on securing it? Will the existing glue give problems with a bond?
carlos515
I was going to wrap the plywood in fiberglass mat soaked with resin. First the bottom then screw it to the existing floor. Then cover it with the fiberglass. My 3/4 ACX floor was covered with 1/4 inch of fiberglass then painted with epoxy primer , then 2k single stage.
I was thinking to encapsulate the 3/8 screwed to the floor with stainless screws. Grind the little bit off the gunwales and tab the floor in.
carlos515
Any suggestions on how to get the fresh glue off? I am thinking to remove my floor and re install a new floor instead of just laying a sheet of ply over the glue. I had a momentary laps of reasoning, LOL. I used Roberts 6700 for glue last year and it is still soft.
Acetone does not remove the glue.
