Advice / Tips for Draining Old gas and checking fuel lines.
Steve51
Long Question – short answer…
I have recently installed a brand new engine and as such I have replaced all the fuel lines and filter etc. to accommodate the larger diameter fuel feed.
I also have about 40 gallons of stabilised fuel (gasoline) in my fuel tank that has been sitting for about 2 years.
Now I need to do two things … firstly I need to check the new fuel lines from the filter to the tank against leaks etc. and also need to check the condition of the old fuel.
Therefore it would be easier to draw the fuel from the tank from the new filter. I have tried a simple hand transfer pump and a bulb fuel line but that didn’t work.
So .. Just thinking of using an Edlebrock self priming 12v electric fuel pump for carburetors to undertake this.
Bearing in mind there is no fuel in the fuel lines at the moment, so will this work?
I initially wanted to draw a couple of gallons first just to check the condition of the fuel; I can even rig up a sort of fuel polishing setup with extra filter etc. if needed.
Thank you.
Your 2 year old stuff is no longer fuel
Pump it out, clean the tank, get fresh fuel
