bruceb58
- Mar 5, 2006
- 30,787
The Bearing Buddy has a pressure relief that lets some grease out. Bearing Buddys do fall off but that is a caused by vibration with a poor fitting hub. I have bearing buddys on my trailer for my Wellcraft and never have an issue. That trailer has disc brakes and I travel down steep mountain passes in the Sierra Nevada. If you fill the bearing buddy properly and only pump until the cylinder first moves, there is never an issue with a blown seal.I figured someone was going to argue that is why I posted the Timken link. I have seen a few blown or leaking hub seals because of this. Also seen bearing buddies pushed off of hub when they are over filled. You have to all room for expansion.
http://www.bearingbuddy.com/install.html
fill the hubs completely
Also, EZ-Lube hubs get completely filled if you inject grease into them and pump until the grease flows out the front cap.
