Finally got it in the water yesterday. 4 ft seas greeted us. Lots of fun. If it wasn't for you guys
it wouldn't have been possible.(no not the waves just being there !) Many thanks. Only two issues left
maybe these will be easier than the last ones.
1. After running for about 2 hours pulled into a sheltered area and idled in a tight circle while checking
the engine etc. When I turned full left / right I got a clicking noise. Would not go away if I turned
the other direction. Would go away if I straightened out and put cycled from forward to neutral then forward/neutral.
Same with reverse.. reverse neutral then forward/reverse.
2. When battling the waves I went from half throttle (2000rpm) to full and the engine went back to idle.
Pull the throttle back and the engine went back up to (2000rpm). I am going to run it up on the trailer
and check it out first. Seems like the throttle goes over center and goes the other way. Doesn't stall tho.
Thanks again for all the help.
OTG
OTG
