WinnerCougar74
- May 12, 2020
- 253
It's always good to find aftermarket parts since originals are hard to find and expensive.
I got this epoxy filled coil on ebay for $23.75. The title said "Blaster Ignition Blaster SS Coil High Voltage -40,000V Male E-Core Square Epoxy" So far it is working just fine. I bought 2 just in case. It should be an easy swap if it fails. You just have to drill out the one hole so the screw will fit. My motor is a 1974 135hp. You also have to put a new end on the coil secondary wire. I replaced all the wires so it was no problem.
