alarm
hondon
Re: alarm
That is is your oiler alarm so you will need to find out whats up .Unplug the sender and see if the horn goes away.If so the sender is bad .
FranksMerc
Re: alarm
I have the same exact thing happening. May need help finding the sensor, haven't looked it up yet.<br />How would you know the senders bad?
laughingbass
Re: alarm
I have the same problem on a Merc 115hp. On my motor I was told by a mechanic to disconnect one of the two blue wires on the oil sensor module that are connected by bullet connectors. If the warning horn stops then it was probably the float in the plastic oil tank and would need to replace tank. If the horn still beeps then it was probably the sensor.
bluebyyou
Re: alarm
Try topping off the motor mounted tank. Does the beeping stop for a while? Could be a gummed up oil line or a cracked cap.
schaiss
Re: alarm
laughingbass is right on the money! If you follow his advice your problem should be solved.
Elmer Fudge
Re: alarm
Yep! laughingbass is correct,but only if you're not out of oil :( <br />What yr and model is your motor?
FranksMerc
Re: alarm
I have a 94 115 HP, I am looking at Seloc manual. I see exactly what your saying about disconnecting one of the blue wires.<br />If it is the sensor can that be changed or must you replace the oil tank? <br />Is there a way to clean the float and how hard is it to remove the oil tank? <br />This board is great! Thanks for your help.
FranksMerc
Re: alarm
One more thought...I just looked at the schematic again. If I disconnect one of the blue wires to the low oil sensor and it stops beeping couldn't it be either the low oil sensor or the float. If it doesn't stop beeping wouldn't it be the low oil warning module?<br />LaughingBass wrote, "If the warning horn stops then it was probably the float in the plastic oil tank and would need to replace tank. If the horn still beeps then it was probably the sensor."<br />My thinking being that once the circuit is broken it can be anything "upstream" of that.
FranksMerc
Re: alarm
bump....trying to figure out what to do after I disconnect the blue wire. Can the float be fixed and how can you test the sensor and low oil module.
RussFarmland
Re: alarm
thanks everyone solved the problem the unplugged one blue wire as suggested the beeping stopped then plugged wire back in and turned the oil tank upside down beeping stopped replaced oil tank and everything is fine thanks again
