alcohol stove ?
acampane
So i have a electric/alcohol stove...the electric aspect works great. The knobs for the alcohol end seem "frozen". anyone run into this or have an idea for a fix...thanks. its on a 1990 25ft sea ray...if it makes a difference.
dockwrecker
Re: alcohol stove ?
Is it an Orego stove with the canister under the burner? Does it have the wheel that closes the sliding flap under the burner? I clean mine up with a spray of Easy Off and a little OO steel wool when it gets sticky. Get the top loose so you can get under it, but be careful not to spray the circuit board for the electric control! Should be fine.
dan t.
Re: alcohol stove ?
The real fix is a Force 10 or Dickenson propane stove
