dwheeler7676
- Dec 26, 2007
- 14
Re: alignment issue
Hi Chris,
Thanks for your clarification (especially the diagram), but if the engine was simply pulled, set aside (where only only certain auxilliary components where replaced - exhaust manifolds, w/p, thermostat, starter, etc.), and then the engine put back in place, wouldn't the components you mention have remained in place, as is?
In your experiance, is it likely that either of them (rubber washer or spacer) could simply fall out, especially both sides, and then go unnoticed during reinstallation? Isn't the [metal] spacer captured above the pressed-in rubber mount?
(Note: The reinstall went fairly smoothly [other than tight fit going through engine hatch], the coil and fiber washers were in place as the engine was lowered onto the rear transom plate and front engine mounts, bolts guided and inserted, snugged and torqued according to manual specs. I admit, it 's not easy to run down to boat now, open and crawl under the cover, work my way into the [dark] engine compartment to take a peek, but I'm pretty sure those items were [always] in place, before, during and after.)
Given the above, what do you think? (Regardless, I will check this eventually.. likely in the spring...
Thanks again!
"http://www.dougrussell.com/partscatalog/components/index.cfm?fuseaction=viewparts&colid=04&coldesc=230%2F5%2E0LX%20%284%20BBL%2E%29%20%20%20%20%20%20%20%20%20%20GM%20305%20V%2D8%201987%2D1995&index=1014&block=360&BlockNumberList=80,70,50,60,470,490,180,140,160,170,130,150,270,250,260,240,110,440,450,460,90,100,350,340,190,200,370,360,120,290,300,480,0,410,400,310,280,390,380,430,420,320,330,210,220,230,20,40,30,10[/url]
"http://www.dougrussell.com/partscatalog/components/index.cfm?fuseaction=viewparts&colid=04&coldesc=R%2FMR%2FALPHA%20ONE%20%28Transom%20Assembly%29%201983%2D1990&index=2203&block=10&BlockNumberList=230,50,250,0,60,70,100,80,120,110,90,130,20,30,40,190,180,140,160,150,170,240,220,200,10,210[/url]
I suspect you have mis-understood my last post. I am not referring to the fibre washer with the double coil washer inside it. I have read your posts that you installed that. I'm referring to the spacer inside the flywheel cover that goes in before you press the rubber mounts in. Refer to the diagram, item #3....
Chris.........
Hi Chris,
