Fishermark
- Oct 19, 2003
- 5,620
Re: allignment help
"How easy" is a relative term. How much grease are you putting on the bar? You want a very slight coating -with none on the nose.
The outdrive will never just slide on. There is an o-ring that needs to go through the gimbla bearing. That will often require a "kicK - "nudge" - "push" - "shove" whatever you want to call it. Now it shouldn't take two people, but it always takes some "persuasion."
Be sure to grease the o-ring or it can be very difficult to install.
