alpha 1 drive does not move
ag1057
07 alpha 1 drive does not go down .i can hear the motor running.fluid in canister. ??
Re: alpha 1 drive does not move
Ayuh,......
Has it been in the Up position for awhile,..??
If So,......
Have a Fat Friend Jump on it a few times........;)
Don S
If So,......
While they are jumping on it, hold your finger on the down button.
Once it starts working again, it will be fine. Just remember to do one thing next time.
When you put the drive up and the pump motor bog from the pressure, just hit the down button for a second to unload the pressure off the system. Then it will come down next time.
Ayuh,....... Thanks Don,......
I guess I should have mentioned that too.................;)
