It's a 1992 Stingray 556zp with a 3.0 and a Merc Alpha 1 Gen II. I bought this boat for $800 dollars and it'd been sitting in my buddies parents backyard for years.
Anyways I just replaced the starter and finally put it in the water last weekend. Everything was going great until I tried to engage it into gear. Basically it revved and never engaged. I'm not sure if you you can see it but at 12 oclock there's a hairline fracture on the lower unit above the prop.
When I took the prop off the coupler basically was loose like a washer might be an came out after the prop. Also, when I turn the prop by hand out of the water there is no resistance in either direction.
I got a prices on lower units and it's going to run in the $750-800 range, hopefully there's a cheaper solution.
Also when I dumped the boat in I noticed that the boat had taken in a ton of water in the 2 minutes that I had it on the water. I was thinking that this was a leak of such magnitude that it could only be caused by a tear in one of the bellows. Does that sound right?
