Alpha One - Can't remove upper housing
rstier
Hi,
I have to replace my Gimbal Bearing but I am unable to get the upper housing of my Mercruiser Alpha One off. After looseing the six nuts securing it, I can only move it back about an inch. I have tried everything I could think of to loosen it including prying from behind the drive with a board and dropping the drive (with the trim cylinders off) in hopes of freeing it. Any ideas I can try?
Thanks!
Ron
JustJason
Re: Alpha One - Can't remove upper housing
1. make sure your in foward gear...
2. use the trim rams to push it off....
flabum
As Jason said and put a 2 X 4 where indicated in the picture and raise:
rstier
Great ideas, I didn't even think of that. I tried that method and it popped right off.
Thanks to you both!
Ron
JustJason
double check your alignment before you go to put it back in
