Alpha One Gen 2 Gimbal Housing Anode - no wear
void7910
Just replacing my anodes and noticed the old on the gimbal housing has no wear. Grabbed a multimeter and sure enough no connection to ground/other anodes. There doesn't look to be direct anode to outdrive contact because this is the one with the small gasket so I assume the connection comes through the screws? Ofc when jam the multi meter probes in the screw holes I can't really get much of a connection either, i assume they're maybe corroded on the inside? Any thoughts or tips on how to clean the inside of the small screw passages?
Bt Doctur
First make sure there is a bonding cable from the steering arm to the transom housing and from there to a bolt on the engine
alldodge
Does your boat sit in the water plugged into shore power?
void7910
FWIW I can't get a reading on the meter between the screws when screwed in (without the anode) so I don't think they're making contact anywhere :\
alldodge
Nope. No power while moored.
With it not plugged in than anodes for the most part are not needed
What size/type boat do you have?
Unless your boat has a Mercathode then anodes would never wear. The Mercathode would also use power from your Bat
void7910
It's a 20ft Glastron bow rider and I can assure the anodes do corrode in the fresh water I am in. The rest of the anodes (trim + prop + drive plate) are all fairly pitted after last season. The gimbal anode was the only one that is smooth as the day she was manufactured.
Cleaned the snot out of the screw passages and still cannot get a connection. Any chance those are are isolated by design? ¯\_(ツ)_/¯
alldodge
That one is isolated somewhat because of the trim line manifold Gasket
That is also where the Mercathode would be if it was installed. The anode is removed and Cathode is installed
void7910
Yeah I was noticing that...where it installs on the gimbal though (stud?) should carry the connection through tho, no? I don't really want to tear the whole thing apart to get connectivity but not sure what I am left with at this point.
alldodge
Since all other anodes have continuity to the engine block and the gimbal housing does not, than only way I see is get into it or run a connection to one of the other anodes
Guess your having erosion problems with the drive and transom assembly?
If so might want to install a Mercathode in place of the anode
void7910
Not terrible corrosion yet. A little on the trim rams and a bubble on the transom housing. Trying to nip it in the bud before it gets worse.
alldodge
Actually don't think you have an issue, that's just time a bare anodes wearing away over time
