Alpha One Gen II loosing oil
alldodge
Unable to answer why other then increasing pressure will help keep it sealed. Testing at 3 psi and rotating shafts "may" show something. A vacuum test may also
Kubaat3lover
I didnt do vacuum test, only pressure test+rotating the shaft and nothing, no pressure drop, no bubbles..
Do You think to fix it or live with it? I know the prop seal is real pain to replace...
alldodge
Guess it depends on how much. No one likes putting oil in the water but if your loosing a few ounces all season I would live with and recheck every year. If your loosing more, then might want to go for new seals
alldodge
Yes, as shown in previous post, but thought you checked those?
Kubaat3lover
Yes Nothing Maybe the hose outside the boat...
But the boat is in the water already
