Alpha One Gen One U Joints: Part number help
90stingray
Hey i looked at the sticky in the adults only section under u joint part number and there were only part numbers for the gen 2 drive. I would like a spicer part number or something i can get at a parts store on the cheap. Have an alpha one gen one, s/n OD462242. 1.84 Ratio behind a 4.3 V6. Thanks for the help.
Re: Alpha One Gen One U Joints: Part number help
you can look the parts up by mercruisers website. you enter the serial number of your outdrive and it will give you the proper part number
Ayuh,... Alpha 1s, 'n Gen.IIs are the same...
