Bass2mouth
- Dec 19, 2012
- 40
Hi guys I have been a long time follower and recently joined to ask some questions about my new this summer boat. First the boat is a 1978 sea ray SRV 220, the motor and drive are a bit more complicated. The mercury marine tag on my motor is serial # L033402. = 5.7L alpha one.= With the old style log manifolds and cooling system and A Rochester quadrajet carb.
The problem that I am having is that I have very restricted almost non existent water flow exiting the exhaust ports on the upper out drive, and the through prop. Im assuming that my problem is a result of this. The problem.
Boat starts idles and runs perfectly, but after on plane for 5 min it will begin to overheat, and continue to climb in temp until I pull back on the throttle to 800-1000 rpm and putt, or put it in neutral and idle, then it will cool down to normal temp, back up on plane or any rpm above 2000 and the circle starts over again. The boat will run at below 1400 rpm all day with no issues.
Boat is raw water cooled.
I have replaced the pump in the lower unit - complete kit. And still same thing.
The old impeller was missing all but 1 fin, I tracked down little bits and pieces in the therm housing, but not all of them.
What I have done/ observed
1. Removed the thermostat housing- no thermostat in the housing old owner must have removed it.
2. Removed line from raw water pump in lower unit just after the steering cooler- water flow is good, flows 10-14 inches vertical.
3.removed log style manifolds and risers- pressure tested water passage to 18psi with air and held for 10 min. no drop in pressure
4.Removed hoses from therm housing- plenty of water flow.
5. Poured 1G of anti freeze down the y pipe from wear the elbos would connect- slowly dripped out the exaust ports but not the through prop.
6. Tried to find the flappers/shutters in the y pipe. Could not see them. Did it ever have them? Are they stuck in their some wear?
Thanks for the help guys I really appreciate it. Is their any way to check if the y pipe is clogged with out pulling the engine? Any ideas? Any help would be great.
Thank for youre time.
