Alpha One Questions
Rusty Boater
I have a 1999 Bayliner with a 3.0 and Alpha 1.
My questions...
1. I have a slight oil leak, (meaning i topped off the lube monitor in March and it was on the add line before I left to hit the lake on sunday. I topped it off and appears none has been lost. Can i keep an eye on it for the remainder of the season and then deal with it after the season?
2. I was going to pull the drive and check for oil in the bellows. If i do so will i need to realign with the tool? Just trying to determine if i need to order the alignment tool now.
3. Has any one built a stand to hold their stern drive while working on it that i could copy?
Thanks for all the help. You all make boating cheaper and more fun!!
Fishermark
Re: Alpha One Questions
My questions...
1. Don't know. Maybe air was trapped??
2. Don't need the alignment tool just to remove and replace the outdrive. It is a good time to check the alignment however. And since you will eventually need it anyway, it is a good time to get one.
3. Many have built simple wooden stands - do a search and quite a few will come up.
chiefalen
You using it in fresh water or salt?
Fresh water won't hurt as mush as salt.
What you lose 4 or 5 ounces?
I remember someone did post a picture of a stand they built. I just use a vise.
In my own inexpert opinion i would wait till the end of the season and deal with it. 5 months and you had to add a little.
Rusty Boater
Fresh water ONLY...
Yeah maybe 4 or 5 ozs at the most.
