alpha one questions
zachb91
how does the alpha one hold up with a mild built 350?? i just got done puttin one in and fired it up u can tell it has a mild cam but thats all i know about the motor bought it off a buddie
achris
More fish than mountain goat
Re: alpha one questions
300hp maximum through an Alpha...
When you say 'mild cam'... If there is an sort of hunting at idle, you're likely to get reversion... Water pulled into the cylinders through the exhaust valves.
Ayuh,.... 'n it's Gotta be able to Idle at 650/ 700 rpms, in order to shift Right....
