alpha one shift shaft tool
sti1471
I need to remove the lower shift shaft from my outdrive, but there is a "nut / bushing" that requires a special tool. Does anyone know of a way to make a homemade tool, or a way to remove this nut without buying the special tool?
Thanks.
natemoore
Master Chief Petty Officer
Re: alpha one shift shaft tool
Thanks.
Here are some homemade tools I made for my 470 rebuild. I used sockets, nuts, and threaded rod to pull out a bunch of bushings from my lower unit. Maybe one of these is what you need?
http://forums.iboats.com/showthread.php?t=353035
It's post #7.
Nate
sti1471
So does this brass brushing that is around the top of my shift shaft screw out, or is it just wedged in place and needs to be pounded out?
Bt Doctur
The bushing unscrews,BUT you must hold the splined shaft down while removing the bushing.
A tool can be made using a 3/4 impact socket and a die grinder to cut in the 2 legs needed for the bushing.a 1/4 inch socket is used on the splined shaft as a internal spacer for the 3/4 socket.
Check your messages
haulnazz15
I have the actual used to remove that bushing if you want to buy it. PM me if you are interested.
natemoore
I read your post hurriedly and sent you an irrelevant link, but this jogged my memory. I made a tool to remove the bushing (if it's the one I'm think about) with a section of black pipe. I welded on a couple of wings that fit the slots and used vice grips to turn the pipe. Forgot to include that one in my improvised 470 tools thread.
I've got a little flux core welder, and I save all crap metal for just such occasions.
