greg82255
- Oct 26, 2009
- 781
Hello,
I have a 1986 Merc 260/Alpha One. I was docking in some shallow water this weekend and therefore had to trim the drive high up to keep it off the bottom. I noticed that when the trim is up high, the engine won't shift all the way into reverse. Forward isn't as much of a problem - it usually stays in gear but sometimes jumps out. In reverse it just grinds the gears so I move it back to neutral. Upper shift cable is new, but I'm not sure when the lower shift cable was last done. I was planning on doing it this winter along with the bellows. By the way, when I say trim high up, I had to go above the trim limit using the trailer button. Any idea what is going on here, or is it nothing and this is normal?
