chevymaher
- Mar 29, 2017
- 2,937
How can I test if what I have is working or not, and if not, do you have any idea how to fix it?
If adjustable air pressure is available, standard calibration speedometers should react to the following pressures: 5 PSI = 20 MPH; 11 PSI = 30 MPH; 19 PSI = 40 MPH; and 30 PSI = 50 MPH. Probably nothing wrong they pretty tough. This is what I used to test mine and it is right by GPS in the water.
Another interesting factor if you are in a stream or river. Gps reads speed off of the bottom not the water. If the water is moving in a stream that makes it off to. So unless the body of water you are on is still they are no more accurate then the boats.
