Aluminum risers
blando
I need new risers and i found aluminum for $99 each.. Are they inferior . I would think aluminum is better ??
Marine Engine Depot. 4.3L_262ci - 5.7L_350ci Mercruiser Style Aluminum Exhaust Riser.html
Great on fresh water if you need to loose weight and keep on top of your maintenance. Not salt water friendly
blando
Primarily salt water at this point. Makes sense.
Any opinion on best low price risers for wet system.
Either stick with cast iron,
Or switch to stainless
There is no good "low cost" option
achris
More fish than mountain goat
Good no cheap, cheap no good...
(Or as I told a friend this morning, Jeep no good, good no Jeep. :ROFLMAO: :ROFLMAO: :ROFLMAO: )
Scott06
Barr or OEM merc hold up well neither are low price. What ever you go with make sure the surfaces where riser/elbow seal are flat
