elwilliams13
- Jul 4, 2003
- 137
I heard somewhere that a stainless prop's heavier weight puts more strain on the gearcase than the lighter aluminum. Any truth to this?
Sorry Kenny, but I think this is not true. This depends on specific gravity, so this 2/3rd less does not apply, at least not to props materials like aluminum or steel.<br /><br />Any body weights less in fluid only by a weight of fluid it displaces. <br /><br />In case of steel prop in water, 18lb prop will displace about 2.15 pints, ant this much water would be little more than 2.22 lbs. So this prop weights more than 15.5lbs in water. Salt water would not change it muchthat under water, gravity has 2/3rds less effect. <br />18lb. prop out of water weighs 6lbs. under water.<br />
