 Sorry my 21 P prop is a stiletto I will see if they have a 17 pitch
one would think so.... if it is the same model of prop it SHOULD perform the same except be the correct pitch for your motor.... Understand though that there is more than one model of stiletto prop ... make sure you are looking at the right one
If your boat is reaching the top of its WOT RPMs with the 17 and plowing one would think that the proper prop in 17P would allow it over rev due to the hull running more efficiently with the good bow lift. Kinda like running trimmed out verses completely tucked. How fast does your boat go with the 17P? What kind of speed did you get with the 21P?
yeah its the advantage 2. Sweet ill take a look at propgods
Yep a 17" diameter prop wouldn't come close to fitting on his motor.it's 17" PITCH not diameter
The recommended prop for your application would be the 17 pitch Mercury Tempest Plus.
The Tempest Plus would run great on that hull. Tons of bow lift.
