Amb fuse
stemar
Hello,I installed recently a speedometer, tach, voltmeter, water temp and fuel gauges. I all installed them in series connection. Can you please tell me how many amb fuse to use, 5,10 or 20??<br />Thanks
AndyL
Re: Amb fuse
Without knowing the exact set up and whether or not you have the internal backlights on all the time it would be a guess. If you have access to a multi meter put that in circuit with maximum load applied. ie Instrument lights on also. If you have not got a multimeter and the instrument packaging does not give you an idea of each current load for the relevent items try a 5amp fuse and see if it takes it. My guess is that it would.<br />Take care and seek proper advice from someone qualified if you have any doubt as the cost of an electrician compared to the cost of an electrical fire in the dash does not bear thinking about.<br />Andy
Scoop
Re: Amb fuse
Stemar, why did you install them in series? I may be misunderstanding.<br />In a series connection, each item drops voltage so each would not be getting enough voltage to work properly. They should be installed in parallel. Run a line and branch each off that line. The instructions for each should let you know what size circuit they should go on. Also, I would not install them all on the same fused line or when the fuse blows, none of them will work. That would be bad.<br />You don't want to be stuck on the water without a fuel gauge, but being without the speedometer is no big deal.
CalicoKid
Re: Amb fuse
Are you sure you wired them in series? Or did you daisychain the grounds and hots separately(parallel)? What size wire did you use? If you have small wire + big fuse the wire will blow before the fuse and that's bad unless you want an insurance claim! Most guages and the lights in them don't draw much. 5A and 16 guage wire would most likely cover it. Be sure the circuit(s) are correct before heating them up, you don't want to ruin those new guages.
stemar
Re: Amb fuse
Thanks guys,<br />Yes I quess your right I connected them in series.<br />I will use 5 amb fuse.<br />Thanks again
stemar
Re: Amb fuse
Thanks guys,<br />I quess you are right. I connected them in series.<br />I will use 5 amb fuse.<br />Thanks again.
Arnold96
Re: Amb fuse
If you wired them in series as you said, they won't work. If you wired them in parallel or change them to that way I think a 5 amp fues would be sufficient. 5 amps X 13.8 volts = 69 watts. So really a 1 or 2 amp fuse would be enough for the backlites alone, as each bulb is probably only a watt or 2.
