Re: still on hold
Re: still on hold
YD, so in your experience epoxy systems should cure within a short period of time (when mixed properly)? I've read that some systems take longer than others and some take more than a month to fully cure at room temperature. How much of a role does temperature and humidity play in the curing process of epoxies (time wise)?
I've switched from plain warm water to "warmer" water and dish soap for the "scrub down". Right now there is very little blush rubbing off, if any. So, hopefully, when the weather stabilizes I'll be able to do a final scrub down then sand and prime.
Re: still on hold
I dunno man .. If it was mixed properly and both parts are for the same system .. then it should have cured without having any more blush surfacing.
Have you tried soap and water scrubbing on a spot or two ?
YD.
