ammeter vs voltmeter
itsaboattime
Hey guys, I have an '83 Johnson 50 horse. I'm wondering if I should install a Voltmeter or an Ammeter to keep track of my charge on my battery. I have a few lights and a stereo installed in addition to my depth finder and running lights. I fish for cats quite often at night and the x-tra light is really handy when landing a big cat. I guess I'm just wondering which will give a more accurate account of how much draw I am putting on my charging system.
F_R
Re: ammeter vs voltmeter
An ammeter, properly installed, will show whether current is being put into or drawn out of the battery at any particular moment.
A voltmeter will show if the overall charge rate is enough to offset the overall draw. In other words, if the voltmeter reads higher with the motor running than it does with the motor stopped, you are putting more juice into the battery than you are drawing out.
Neither one will show the state of the battery (full charge, half charge, etc.) Before somebody yells at me, I am speaking of a common dash-mount voltmeter which is far from being precise enough.
itsaboattime
I'm just speaking of an in dash myself. all I need to know is if I am pulling more than I'm putting into the battery and by how much.
kenmyfam
Theres nothing quite like the warm and fuzzy feeling of 2 batteries or one of those booster packs on board either.
ebry710
Ensign
I like both on the dash.
The amp meter I used for the charging system with the engine is on and battery discharging when the engine is off.
The voltmeter tells me power in the system. If engine is running I will monitor how high and how steady the voltage. When the engine is off I will monitor how the battery maintains that voltage.
