Anchor suggestions
ESGWheel
I look foward to your write up. Please keep in mind that depending on conditions it can be unsafe to haul and anchor from the cockpit. Also note that in various write ups involving this method folks highlight the need to be able to release the 'A-Line' from its aft cleat in case of emergency. You will loose the anchor but... And that is why in the video he talks about having a floating line. Not suggeting you go that route to start with. Instead if this process works for you then look to refine it. Good luck!
IslandExplorer
Lot of good info here. The rode chain really does make a Huge difference. Also the anchor weight and design. Personally I absolutely love my mantus 13lb anchor. I got it after extensive research and watching loads of actual underwater videos of anchor performance in different conditions. What triggered this priority being suddenly so much higher was bc I had a little anchor drag incident with a danforth resulting in my boat getting beached as the tide went out while I was away hacking through brush on an island. Bad surprise as the bad weather is rolling in and your stuck waiting for hours! lol The mantus, which is a plow type very similar to the more common Rocna, is really easy to handle with the big roll bar on it and it sets and re-sets faster than you'd believe in all kinds of bottom substrates. Even with very little scope/line let out. A little overkill with anchor setup is ok. I'd grab one of those along with a lewmar anchor rode that has 15' - 20' of galvanized G4 chain braided into the end of 200' of quality nylon rope. That way if you get sick of the rope trick (which works great- don't get me wrong) like I did and install a future windlass- you already have the correct rode for the windlass to use! Windlass' require specific rope and chain so if you buy one you often have to get a new rode too. Even the smallest lewmar model (Prosport 550) handles that anchor and rode perfectly and it is So nice to push button anchor. Best upgrade I did on that boat. Once you have a windlass- its tough to go back.
