waterwezl
- Apr 5, 2008
- 104
Was trying to remove both consoles today when I got tangled in an extension cord....fell on front of the engine and I heard a crunch.
Well....there is no motor mount on the front of the engine so the transom is supporting the whole sha-bang(I know! I know! It's one of the things on my to-do list). I started looking and discovered the source of the crunch. The drain in the back of the boat is NOT sealed so I was looking at exposed wood in the transom. Well...I guess you could call it wood, some of the bigger pieces I dug out of the little hole resembled wood.
Long story short.....removed rub-rail and am working to lift off "cap". Gotta pull the engine and outdrive to make transom repairs. How do I support the hull sides while it's apart? I thought about cutting 2X4s to length and screwing them from the outside across the inside of the hull. Any other suggestions would be welcome.
Thanks, Jason
Thanks, Jason
