Annode location
3ric
Hello all, I have a 22’ Lowe pontoon and I was pondering putting an Annode or two on the toons. I am wondering where to put them. I have lifting strakes on the inside of each toon and was thinking of attaching them to it. (Inside of strake ? Outside of strake?)
My thoughts being that although I have brackets on the back of the toons, if they were on the underside of those, it might get pressure from the trailer boards if I wasn’t careful as my brackets are over the boards a few inches when loaded. Or maybe I can put them on the top of the bottom of the bracket?
most are on a bracket welded to the back of the toon logs.
3ric
So the bracket is the standard. Can I mount it inside the bracket or does it need to be in direct contact with the water?
jlh3rd
this is where I put mine
