TTavenier3
- Jul 18, 2012
- 105
ok im a auto mechanic not really a boat guy but now that im getting into boat and what not i thought i found a sweet deal. my bad but i was Fudged. the boat floated and didnt leak "i thought" and just needed carpeting on one section. so i when ahead and bought this boat. i decided to rip the old carpet up and replace it all to then find all the corners where rotted out and the floor was wet. i live in iowa.. we havent had rain in a long time. i started to hammer on the wood to find if there is more rot in other places and the slip. hammer goes through the wood and into a water puddle. so i started to rip it out by hand and found the foam floating. weird huh. but no wet spot outside the boat. well i thought. never the less now im into a project to pull all the parts of this boat apart and fix the rivets and floor. i dont know if im going to use carpet or not. my question is what type of wood should i use. treated wood? (green) should i apply resin to the top of it. do i have to fiber glass the top of it or can i just apply resin. also after i replace the pop rivets and what not can i apply resin over all the tops. or should i seal it from the inside. how should i go about water proofing this damn thing. o guess i should have started with it is a 1980 starcraft kingfisher 160 boat. its a side consule boat with a 55 hp suzuki motor on the back. which reminds me after poking around i found the wood where the motor is seems soft to me. i cant poke all the way through it but it has alot of cracks in it. long side to side cracks like wood bark peeling look. never the less how hard is it to fix all this, i really dont want to scrap this boat but i dont want to spends 1200 bucks fixing it either. i figured resin sealer and wood would cost me 300-400 tops. and then making a deck in front of the steering councle be included in that. i do want to make a live well under the front deck also. so plumbing for this would probley be around 50-100 bucks. i just want a fill and drain line to it. ill have the drain always open with on of those tall overflow tube in it and have a bildge pump contantly running with streamers dropping water all the time to keep the fish alive. maybe ill add an airater also. then i want to add a storage compartment in the fdeck up front which will be easy. maybe 2 pedistool mount to move the 1 chain up front to either side of the front of the boat.
any ideas. restorations done on a very simular boat. any help will be much appreciated. expesually about the wood floor.
