Another Flushing Question
mike_i
I have a question to those of you that run some type of de salt fluid thru your outboard? I have a 2016 Yamaha F150xb with 280 hours on it. I run in saltwater only and at the end of the day I run the motor for approx. 10 minutes in a 100 gallon trash can and do it again the next day before I put the boat to bed. I've had several containers of de salt solution and have decided to use it up. I first removed the thermostat to see what it looked like. I should have a taken a few pictures of it but didn't. There was some corrosion but was able to remove it with no problem. I tested it in a cup of hot water and it did open fully at 140 degrees and then fully closed. So my question is should I run the motor without the thermostat? I plan on letting the water cool then run it again and repeat the process for couple of days.
jimmbo
To the first Part, No.
To second Part, Running it a barrel, just recirculates/reintroduces the Salt, and reusing the Water the Next Day, just repeats that. Have you considered flushing it with Fresh Water using a Hose, and Muffs?
mike_i
I've had issues with running with muffs on other outboards but the main reason is if I used muffs I'd create a huge lake of mud. I've never been concerned about running the motor in the trash can since it's 100 gallons of fresh water vs I'm guessing a few gallons of salty water. After I start the motor I taste the pisser water and the salty taste is gone in a few seconds.
Chris1956
Remember your outboard drains completely after you pull it out of the water. You are dealing only with the salty residue from whatever residual water (a few oz at most) remained or evaporated.
If you run it on a flusher, until the thermostat opens, and then a bit longer, the salt will be rinsed out. No need to create mud lake each time.
frustratedboater
Just my opinion, but the motor only holds at best 1 to 2qts of water when trimmed down. Mix that in 100 gallons I'd say you've got a bunch of flushings ahead of you..
