Another one...Upholstery
JDA1975
Re: Another one...Upholstery
So today I broke my shop....left this huge hole in it!
then someone fixed it
Just couldn't get all the boats through the 7.5" double glass door, so I added a 12' Garage door....got the garage door, at a garage sale (go figure) for 150 bucks, then 60 bucks in wood to frame it....so not bad added a 12' door to my shop for 210 bucks!
Woodonglass
Now THAT is way kool. Can't wait to get there to see it in person.
JDA1975
lol woody, wont be long now....got to thinking though....if your coming to visit, why do I have to work!?!?
Woodonglass
I'm SURE you'll figure out a way to MAKE me do all the work and you do the SUPERVISIN'
MRS
My first test try had this vinyl for pratice I cannot get the corners any good but will keep practicing. This is going to be a armrest sooner or later. I have good gray vinyl that I will use when I get the corners better.
jbcurt00
For corners, don't most upholstery shops have some pointed 'sticks' made out of something stiff enough to help get the corners pushed out, but not sharp enough to pierce the vinyl.
MRS: It looks kind of like you need to push the corner puckers out from the inside....
JDA1975
square corners are tough, give the corners a slight curve and it will make it a little easier...if you must have 90 degree corners then you need to cut the "excess" off on the corners...i usually cut it at a 45 angle close to the stitch so the excess does not cause it to bunch
MRS
I really need a slight curve but when I tried it really bunches up. Will try again the more I sew the better it seems to get. Thanks for the reply...
JDA1975
on the curve, cut relief slits every 1/4-1/2 on the band to that it follows the curve, that will help it not bunch up as well...it is good to practice before doing it for real so by the time your ready you should have it figured out
MRS
Jb and JD, Thanks for the replys I will try cutting the reliefs and sewing on the curve. One more question do you use polyester or nylon thread? Thanks again for the info....
JDA1975
Polyester UVR Bonded, like Sungard or Solarfix....nylon is strong but breaks down in sunlight....use at least a v69, but I prefer v92 on marine applications
JDA1975
Woodonglass made it to my house this evening, so going to put his arse to work for the next couple days....
jbcurt00
WOG is in the house!
Sweet, ya'll have a great visit & we expect some work product pix!
Trooper82
Well this ought to be interesting...hope you both enjoy the visit...
sphelps
Looking forward to the JDA/WOG sewing updates ! :caked: Have a great visit !
MRS
O yea we will need some photos of this.:encouragement:
V153
A square doesn't have any corners. That's why they call it a square ...
It does have right angles however. Don't waste your time trying to sew around a 90deg angle. It ain't gonna happen.
Do yourself a favor and add a radius. However small, it'll help. I keep an assortment of circular sh*t around the shop just for that purpose. From bottle caps to 5 gal bucket lids.
As has been mentioned 'relief' cuts in the material help, but if'n yer turning too tight a corner not always.
WOG at the Judges shop?! No good can come from that ... Heh heh heh
MRS
V153, Thanks was just getting ready to practice on the corners right now so your timing was perfect. will try with a coin this go around and see what it looks like Thanks....
JDA1975
Woody hard at work....I think he is having fun
Did not get the seat finished, but we have fit the panel and all looks good
Had a business trip to do in the morning so we never did get started til after 1 PM....tomorrow should be more productive! but we had fun nonetheless.
sphelps
Careful JDA ! Woody may want to take your machine with em when he leaves ! Better check the car and his pockets !:lol:
Nice pleating Wood !
