I posted a problem with the 1992 Johnson 60hp not starting about a week ago or so. It still runs great. However, today, I was on a bad boat ramp, so I used reverse to back it off the trailer. Everything worked fine. I went out on the water, and used reverse again, everything worked fine. All the sudden, reverse quit working when I tried it a third time. Forward works good. But when I put it in reverse, it doesn't engage. I didn't hit anything when I was in reverse at all. If you ever drove a 5spd vehicle and went to put it in reverse, and then when you thought it was in reverse and it wasn't all the way in reverse, it made that tinging sound and didn't go anywhere, that is what my boat did. Sorry for all the run on sentances, I know the grammar was incorrect. Anyways, My reverse doesn't work. This is probably a really stupid question, but is there some sort of transmission, or is it changed by cable? Any similar problems for anyone else? Thanks for the help!
