Another prop slipping thread
alldodge
I would say it must be the coupler has stripped. Would feel better if you smelled burnt rubber after it happened
Don't think the BB coupler will fit, but never tried. They do make a steel coupler but all that means is the splines are steel instead of aluminum. Both use molded rubber to attach
beech2000
water over damn... With OD installed, and with a buddy and a vice grip, stop motor from turning (best way) while you attempt to move prop with a 2x4" If anything moves, pull prop and take to shop and pray it needs repairs and not coupler. I had similar problem with a MC/Proline
Would love to find a way of doing a similur test with the coupler out and on the bench
beech2000
Me too but no burnt rubber odor that I can recall. I could however weld the shaft to the outer dome. Couplers sure are pricey and offer no integrity
QBhoy
You might benefit from Rhoda lifters very commonly used in us to tame wild camshafts by bleeding off duration at low
Rpms
Just noticed this reply. Apologies for not responding. Tell me more !!
alldodge
Don't know about coupler integrity, but I've never had one fail if it was checked yearly. Didn't matter if it was a 4 cyl or up to a 530 HP BBC
Did have one burn up in my early years when I didn't check yearly
Post a want to buy in the Offshore only section.
Scott06
Rhoads lifters bleed off cam duration at low rpms To tame wild cams And create more low end power and idle vacuum. They reduce the effective cam duration by 10-15 degrees below 3500 rpm. Commonly used in hot rods in the US. Probably the first attempt at variable valve timing, but rather than advancing or retarding the cam it bleeds off lift and duration.
beech2000
Well,
I've officially eliminated any and all sources. No other option than to order a new coupler. I am going to order up a new input shaft bearing though as the one shown in picture and still on shaft is scored and worn. Thanks for your help.
Oh BTW should I go with OEM? coupler? any after market version that seem to be equal in quality?
QBhoy
Excellent. Thanks so much for that. I’ll get a look tonight !!
alldodge
Never tried aftermarket but others have and have not heard of problems
Scott06
Well,
I usually go oem. While they are expensive there is too much junk out there
last Sierra item i used , trim sender, never worked right . Limit switch works, could never get the sender working right seems to be reasonably accurate at idle speed but goes all the way up when on plane. Too much pita to redo.
ROY WILLIAMS
Well,
the outdrive bellows of the inside it full the water . u joints / bearings and did the bearing / shafts you was the gear oil in the fall ! the gear oil is the lower port hole ..did the gear oil inspected it ..
beech2000
I had a brain storm.
A loaded down boat that day with a 21 pitch prop and tons of horse power..... I'm thinking.... since nothing found I'm the culprit of extreme prop cavitation. I understand the level of stupidity but that's the only explanation as no smoking gun identified.
Following the event we opened the hatch and no smoke in the engine compartment from the coupler noted. Once boat was on trailer No mechanical failure of any sort in the out drive and prop can't spin due to flow torque designed hub.
Since I have the upper and lower torn down I'm replacing the bearings, resealing the drive, new water pump and putting her back together. Thoughts?
Scott06
Yes completely agree was thinking about this wondering if the prop to hub clearance or slip is greater. I would not not replace the coupler since you are there and the alpha drive either grabs or it doesn’t. You may need a prop with more bite if you go out with a boat load of people…
try a prop like revolution 4 or enertia that has grip See if you have same results
