oops!
- Oct 18, 2007
- 12,932
Re: Another Stringer Repair Question - by a Newbee
beleive it or not.......this is a fix that will work. (if glassed over) and in fact...in the problematic bow stringer area, you can do this.
if the breach you discussed is not in the bow area (more than likely it is) you can just cut out the rot in the forward stringers and sister new ones in.....then glass them to the hull. you can do this thru the acess of the ski locker, or the deck you cut away.
Thank God for you all - I would have just cut out the rot and screwed a sister board on the side of the stringer and glued down a new floor like we do in houses, glue down carpet and head for the lake! YIKES!
