Another water in oil thread! Please Help
SharpeCon
So I have a 4.3L mercruiser V6, I fixed all of my fuel delivery issiues from past threads, now I get her on the water and everything is runnin great! Except a a hesitation at full throttle, no biggie. After about an hour of hard running. I decided to check the oil ( I had milky oil before) But thought I fixed that problem. (bad fuel pump, diaphram letting gas into oil). Ok so that was not the case, I m getting water in the oil from somewhere??? It took about 45 mins to an hour for my dipstick to read about a quart too full... I need some expert advice here! Been reading some of the forums looking for answers, but no luck. Where do I begin to find where the leak is? What do I look for, how do I inspect? Thanks
Re: Another water in oil thread! Please Help
Ayuh,... Isolate,+ block off the cooling system,.. Then pressurize it with about 15psi,...
You'll Hear the leak...
SharpeCon
Forgive me, I dont know how to do any of the above mentioned actions???
