Hi guys,
Mercuiser 350mag/bravo3/Regal 2550
I have just winterised my engine by draining the water as you should but I of course wish to minimise corrosion of the block and manifolds and so I want to pour antifreeze in the block by disconnecting the hose that goes into the thermostat. My question is weather to use the older IAT mix or use the newer OAT type?
I know there a loads of posts about winterising and which is the best and if you should even use antifreeze but nobody mentions the type,
Thanks in advance,
cashwowud
Thanks in advance,
cashwowud
