soggy_feet
- Oct 10, 2009
- 713
Re: Any engineer/techie types here play around with OpenFOAM?
V hull thing makes sense. Just hadn't thought about it that way.
Pontoons.... I might as well build a boat from the ground up if Im going to try that route. Its the hull that holds everything together. Once she's out of the water I'll have to get some good pics inside and out, and I think you'll see what I mean.
Stopped by my friends fab shop this morning, and he was pulling a sheet of steel out of the rack to cut some brackets. It happened to be 12 gauge... pretty close to 1/8". I took the opportunity to see how far I could curve a full width (48") sheet of steel with my own body weight. With some 1" box tube to build a frame I can define the curve of the bow with, I don't think it'll be very difficult at all to form this thing with nothing more than a few anchor points to hook a come-along to.
Bulbous bow is looking less likely from a fabrication standpoint, still thinking about a sharp V to help split the waves, a bit like a canoe...
